I was looking through newegg's video cards and im not seeing much and most of the cards there had no reveiws yet. So whats the best video card for gaming thats under 250 dollars? I would prefer AMD but if nvidia has a better price/performance card in this price range im open to it. Thanks guys
probably a 270x or a 760 are what you should be looking at
ive heard the 270x is just an underclocked 270 is this true? would I be able to overclock a 270 to the equivalent performance of a 270x?
yes you can do that linus has a video on the 270 and there sample overclocked past a stock 270x and performed better. A 270x may overclock better though since it has a higher stock clock speed. The 270 or 270x seems like a great deal at around $200 to me. I am using a 660ti and the performance is great in new games and the 270x is around the same performance so I think you would be happy with it.
Alright sounds good :) Thanks man
No, a 270X has more shaders and a higher clock speed.
