Best GPU for about $200
I saw a Zotac 660 on tigerdirect for 214 and for the same price it does better than the 7850.
http://www.anandtech.com/bench/Product/549?vs=660
So is Zotac a good brand?
I can't afford a 7870. unless it is 220 or below.
Hey also I want a card that will perform better in games like ARMA, BF, Cryisis, Elderscrolls, and GTA games. Those are like the only games I play.
Would a 500w psu 95w cpu work with this?
Between those two cards you are talking about here is the difference http://www.anandtech.com/bench/Product/549?vs=660.
Also if you can throw 15 dollars more you can get a 7870 from newegg http://www.newegg.com/Product/Product.aspx?Item=N82E16814150605
http://www.anandtech.com/bench/Product/548?vs=660
At the moment AMD has been pushing out great drivers for their cards, and look at the bright side you get two free games.
Thanks. I think I'll get that instead.
