Best GPU for a $600 Intel Build
The title says it all. I'm new to building computers so try to dumb it down a bit.
Thanks!
I'm going too assume that you want the builds total cost to be around 600, so with that in mind:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121651&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Probably the best card in its price range.
$200 for a HD7850? you can get a HD7870 for that,hell even a HD 7870xt
where do you live? if you live in the USA, for 200 buck you can get your hand on a HD 7870, as stated above. but if you're planning on saving your money for a better processor, get a hd 7850, and make sure it's the overclocked version. performance wise, there aren't any significant performance gap between a stock hd 7870 and an overclocked 7850. if not, grab the Hd 7870, and overclock it. i live in Indonesia so the prices here aren't as friendly...
