Best Gpu for 300$
This is being used for gaming only no video editing if it matters
If you are in the US I think these will be solid choices.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161412
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127732
is the only difference in price?
Yeah, that IceQ 7970 would be great.
ok thanks for the help
Judging by the benchmarks and temps I've seen fot these two cards, they are pretty much identical, the MSI might have slightly higher build quality though.
