Best GPU for 200-300$
Could anyone advise me on what Graphics Card would be the best to buy for around 200-300$. It doesn't matter whether its AMD or Nvidia just, whatever is the best performance for the price. I'm 15 So I obviously cant afford a 600$ GPU. Thank you to whoever helps.
If you can get a GTX 970 that will be by far the best.
Probably a 280x though for under $300.
That's a pretty wide price range with a lot of competition. You can get the GTX 760 for about $215 but for $230 there are R9 280 cards available. Go up to the higher end and for $270 you can get a GTX 770 or 280x. I doubt any of that helped so the short and simple answer is I'd get this
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202127
Thank you guys for the recommendations, it helps a lot.
These deals are pretty sweet. http://www.newegg.com/Product/Product.aspx?Item=N82E16814127789
You could buy my 770 for $220 :X
you can get an R9 290 for under $300 now but if it was me I'd wait 6 months when the next gem GTX900 series drops should drop the price of this gen under $300
