Best Gaming Headset For >100$
I like the corsair 1500 V2 A LOT, it seems very comfortable and very light, but doesn't look too great, however comfort is the main concern, I am open to suggestions, also as a fellow PC gamer who has never used a headset, does a wired headset ever get annoying? Like the cable dangling below it?
Let me know what you think thanks!
Steel series Siberia V2's.
Assuming the >100$ isn't a typo, Beyerdynamic MMX 300
+1
http://springfieldpc.dyndns.org/shimmie/_images/c00cb24ddc8d2a28862a4f0288d7073e/910%20-%20flame%20gaming%20gimmick%20headsets%20retard%20shitty%20tl%3Bdr%20wall_of_text.png
If you absolutely want headset, just buy discounted Siberia V2. It should work. And wires aren't bad.
so what do you suggest as a good pair of headphones for gaming?
I recommend the CAL. Amazing sound for the price, and you should have some room in your budget for a mic.
I've heard Audio Technica ATH-AD700 is very good for gaming in this price range, but it has weak bass. If you can, try those before buying.
