Best Gaming case for around $100
So I am looking around to replace my old NZXT Gamma case. It's a decent budget case, but I need something a bit higher quality, as the metal on the Gamma is fairly poor quality. I am also planning on upgrading my components in the future, so I need to make sure that there is enough room in there when that roles around.
Anyway, my budget is $130. Right now I was considering the Fractal Design R4, as it seems to have great reviews, along with being silent and well built. But I am open to suggestions. What do you guys think? Any help/input is appreciated.
Just in case you need to know my current specs:
NZXT Gamma (obviously)
M-atx mobo - Upgrading to atx soon though
Corsair CX 500w
Radeon 7870
Hyper 212 Evo
and a basic CD drive
Thanks again!
EDIT: Thank you guys for the information, I think I have enough info to go off of. All your imput is really appreciated.
If you have a mATX mobo
http://www.amazon.com/Corsair-Obsidian-Performance-Computer-CC-9011029-WW/dp/B00BWLL9MY/ref=sr_1_4?ie=UTF8&qid=1388714356&sr=8-4&keywords=corsair+750d
If you have an ATX
http://www.amazon.com/Corsair-Obsidian-Black-Computer-CC-9011015-WW/dp/B006L6ZSWC/ref=sr_1_4?s=pc&srs=2529199011&ie=UTF8&qid=1388714422&sr=1-4&keywords=corsair+750d
I'm a bit of a Corsair I know, you diden't specify what mobo you had and so I covered both possibility's, In my experience Corsair case's stand the test of time, while maintaining good airflow and looking pretty damn sexy as well.
Updated the mobo part, thanks. How is the sound on the 550D?
if you care about sound, go fractal define r4. if not, thats okay, you can still go with it.
Do you think there are any overall better options at that price point? Right now the R4 is about $125 in most places
If you're not in a rush the R4 should go on sale again sometime soon. Usually you can find it for $79-$89. Just keep an eye on the usual suspects (amazon, newegg, etc.).
Yeah, not in any rush. I want to try and get the best deal possible, I tend to make rash decisions.
Don't own one myself, but from what I've heard from many forums and reviews it is as silent as a whisper, providing your CPU, GPU and PSU fans are of good quality. I know I myself have swapped out fan's inside my PSU to make it quieter a couple times before.
The fractal arc midi/mini is a nice case to work with. It's really easy to work in and build in and the r2's have the really nice dust filter and fan implementations that allows you to front mount rad's if you ever decide to watercool. Plus the top mounts are offset so you can fit a huge rad in the small case with your mobo. Plus it's Fractal Design so top notch quality and sleek design.
I have no experience from the Corsair, but as an owner of R4, I would go with it. R4 is not worth all the hype. If someone thinks R4 is a top quality case, he has never owned a quality case.
I like this case but the fractals are great
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139008
For a gaming case, there are better options than the Define R4. Define R4 is designed to provide a COMPROMISE between noise and cooling, that's how absolutely every silent case is made. Some provide more cooling than silence, some more silence than cooling, but for each case marketed as "silent" somewhere during the design phase of the case its cooling potential has been reduced to allow for a more silent operation. The difference might only be a few degrees, but it's there.
My personal suggestion is to buy a Fractal Design Arc Mini (for matx) or Midi (for atx) R2. You can go with a Corsair 350D for matx too, it's a good case, it's all up to you and what you think looks better.
If you are ok with your build being a few degrees warmer, but more silent, then by all means, go with the Define R4. Or the Corsair 550D. Watch at least two or three video reviews of each case before you decide. And remember that each and every time you turn on your computer, you will be looking at the case you choose. Make sure you like what you see.
