I am in the process of putting together an APU build. What is the best FM2 socket motherboard I can pick up for $50-60?
This is what I have found - http://www.newegg.com/Product/Product.aspx?Item=N82E16813157462&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
That was my original board up until I tried to install it only to find it was faulty, sent it back, got a refund, got this http://www.newegg.com/Product/Product.aspx?Item=N82E16813128656&cm_re=gigabyte_f2a88x-_-13-128-656-_-Product
I'm not currently using an APU but my CPU does have a FM2 socket. The mobo has been great so far but I haven't got around to overclocking yet but from what I hear it should do pretty well in overclocking.
Even if you buy an FM2 CPU/APU - don't buy an FM2 motherboard. Get an FM2+ since it's the newer socket and will allow for future upgrades and gives you a few more/newer features.
The board's you're looking at are FM2+ and FM2 boards are probably hard to come by these days as they are getting old, but I just wanted to clarify the difference between FM2 and FM2+ because it's important to make the distinction.
As the others have mentioned, any FM2 CPU/APU will work just fine on any FM2+ board.
