Best fans for corsair H100
Greetings!
I need some advice on what fans to use with my corsair h100, the fans now are too loud (I already knew this) So I was thinking of a few, the Corsair SP120 (twin pack), Silverstone Air Pen or the New Noctua NF-F12.
I personally dont like the noctua as they are more expensive and they wont look good in my build so unless thay are really good I would want to avoid getting them.
the best one out of that list are the Corsair SP12 Silverstone Air Pen for raidators you want high static pressure not high air flow. the Silverstone Air Pen are very good as well you wont see a temp change between. the Air Pen well be the best if you want low noise
Noctua NF-P12 are good with static pressure the ND-F12 are for air flow
http://www.anandtech.com/print/6177
