I wanted to upgrade my h100i fans to something better. I only want to spend around 30 bucks (only need 2) on the fans. Any I ideas? They need to be 120mm, and quiet (under 30dbs).
I have been looking at the F12 from artic -- Those good?
Also the orange Cougars (22 bucks for 2 right now on newegg) Are those good?
corsair af series fans are pretty good iv got 2 of them on my h80i, there the high performance pwm versions. that being said the ones that come stock with hour h100 are actually the same fan more or less, your not very likely to see a temperature improvement by changing the fans out. cougars are good iv got one of those as well, its on its second year of constant operation and not making any noises works for me.
