Okay so I have got my hands on a grubby PC that will be used for Windows rescues, its a Pentium 4 and 1GB RAM, so naturally Linux will be put on this, and it will be a focused PC, for stuff like Drive clones, Password breaking, Virus removal etc etc, what you would find in your standard PC shop, except they use Windows to fix a problem Windows caused...
What distro would you recommend for this? I feel a live distro is too slow, so having a distro I can run on an actual PC and USB satas drives into the PC would help.
Also would KVM/VB work here? like for live versions of Windows, So I can make a VM of that drive? is this possible?
I am currently thinking Cent OS as I feel a stable distro would be much better over Bleeding edge, but if you agree otherwise please give me your reasons, I just feel stable would allow less DT than Bleeding edge.
Thanks!
