Best cpu upgrade from i5 6500 to pair with gtx 1070 ti?
Should i even upgrade my cpu?
depending on the workloads you are using the setup for.
I suppose gaming, well then that depends on the resolution you aim to game at.
1440p or 4K, you dont really have to upgrade the cpu then for like 80% of the games.
But if you want the best possible performance out of the 1070Ti at 1080p,
then you might want a cpu that will boost a littlebit higher on the clockspeeds.
I’m gaming at 1080p.
May i ask which motherboard you have?
Gigabyte h110m-ds2
Hmm yeah well then you dont really have much cpu upgrade options,
on your current platform.
You could trow a 6700K on your board that boosts a littlebit higher.
But other then that, not much other options for your current platform.
You will need a motherboard upgrade if you want more cores.
Its a bitching GPU but at 1080p you should be at max settings and the CPU while 4 threads has legs.
Wait for ryzen 3000 and whatever monstrosity intel makes at the end of 2019.
Your pretty solid at 1080p even 1440p
Yeah the higher the resolution the less the cpu generally matters.
Still with his current 6500 + 1070Ti, it should still be more then fine,
even on 1080p in like 80% of the todays games.
But there are a few games that will be really benefiting from having 6 or 8 cores nowdays.
But on his current motherboard the best option he has a 6700K.
And its probablly not worth bothering with an i7-6700K anymore.
Better to upgrade platform lateron.
True a 6700k even if the MB is not a built for overclocking will give HT
Next year is going to be fun with what AMD realese and Intel promise.
Save up the money for 2019/2020 CPUs and platforms.
Best you can do on your current board (like @MisteryAngel & @Marten said) is a minor upgrade wich is probably not worth the investment.
