Best cpu for a build with a 770 in it
i have a 2gb gtx 770 and im looking for the best cpu for it, i am putting the 770 i have into a new $600 USD build. i would like your opinion on what one i should get. intel or adm it dosent matter to me.
i'm going to assume your purpose is gaming.
The Z97 Gryphon is an Excellent mATX board. the Gryphon Series on the ASUS's TUF Series are awesome boards and incredibly durable. also you can upgrade to broadwell 5th Generation Processors later one if you want.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132133&cm_re=ASUS_Z97_Gryphon-_-13-132-133-_-Product
Also grab a i5 4690k
thanks
