Best Controller For PC? [DarkSouls2]
Hey guys I just got Darksouls 2 and it looks really epic but the M + KB support is hideous, so I was wondering what is the best controller to use with my PC?
I was looking at these:
http://www.amazon.com/Microsoft-Xbox-Wireless-Controller-Windows/dp/B004QRKWKQ/ref=sr_1_9?ie=UTF8&qid=1398548563&sr=8-9&keywords=xbox+360+wireless+receiver+for+windows
http://www.amazon.com/Logitech-940-000117-Gamepad-F710/dp/B0041RR0TW/ref=sr_1_2?ie=UTF8&qid=1398548984&sr=8-2&keywords=logitech+controller
Personally I like the Xbox Controllers size and comfort more, but hey whatever is most functional, I also have 2 wireless Xbox 360 controllers, is there a way to get them to work on my PC?
Specs: Windows 8
Personally I would stick with a xbox or ps3 controller.  I use a xbox 360 with a wireless adapter for most games it works well.
Your wireless 360 controllers should work fine.  A lot of games are designed and labeled specifically for the 360 controller.  You just need the wireless usb adapter.
http://support.xbox.com/en-US/xbox-on-other-devices/windows/xbox-controller-for-windows-setup
I like PS3 controllers over xBox controllers. I just don't like the feel and plastic in the xBox ones. I hear the PS4 controllers are far better with PC compatibility and nice to play with but I don't have one.
If you get a PS3 controller get this for the driver it is flawless and tricks the PC into using the PS3 controller as and xBox controller so full compatibility will all modern games. http://forums.pcsx2.net/Thread-XInput-Wrapper-for-DS3-and-Play-com-USB-Dual-DS2-Controller
I'd just get an Xbox 360 wired controller. The wired controllers are a lot lighter than the wireless ones, don't need batteries, are more responsive and cheaper. Plus you don't need a special receiver. They just plug into the PC with USB.
That is what I use for my PC.
