Best connector to use?
Hi all!
I'm about to buy a Dell UltraSharp U2713HM, and hook it up to my Asus Nvidia GTX 660 Ti OC. This will be the only monitor connected to my GPU. I was wondering which connector I should use for the best performance. Both the GPU and monitor have a DP, HDMI, and DVI-D port.
Thanks!
Evert
I've always gone for DVI because sometimes HDMI is limited to 1920x1200 depending on which version is used.
edit - But HDMI supports audio so if the monitor supports audio pass-through (I think yours does) that can be a pretty cool feature
I'm fairly certain that HDMI is the best route to go.
