Recently I have been looking into getting 2 (possibly 3, if possible) closed loop water coolers, one for my CPU and one for each GPU. I currently have the NZXT H440 case, so I definitely have room for 2 closed loop. So here are my concerns, is it possible to fit a 3rd for another GPU cooler and what are the best closed loops for GPUs. I have an idea of what to buy for the CPU, the Corsair H100i. Also, compatibility is not an issue as I am going to be upgrading most of y hardware and I will match all of the components. Please let me know if what I am thinking is at all possible or I should just go all out and build a custom water loop.
Thanks for any and all help, Lonnie D.
P.S. I am looking for a black and white color scheme.
Even though the G10 is made for corsair products, I recommend the 140XL. It nearly performs as well as an H100i granted you can put up with the JetFlo fans. I actually used Corsair mounts (one of my cm ones was stripped) and everything mounted just fine. Granted it isn't too expensive. For the cpu I recommend the 280L it seems to do pretty well.
