Best Closed Loop 120mm Liquid Cooler
Title says it all guys. I would go for a 240mm one, but there isnt enough room for one above the motherboard in the CM Storm Enforcer.
Thanks for your suggestions!
Coolermaster Saidom 120 xl maybe.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103180
Your best bet would actually be a large air cooler, 120MM AIO's arent worth it for the performance you get.
Yeah, I agree with BeyondNight.  And even then, I wouldn't recommend anything fancy.  I would go for something like this...
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
It offers stellar performance for a much lower price tag.
or the noctua dh-14
if you want to look at an air cooler i can say this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709020
Phanteks PH-TC12DX_BK  push pull setup.
In responce to Giant, I do actually have a noctua NH-D14, and It's keeping my 2500k cool at 5GHz (never goes above 65 ish which is epic :D), but I wanted to free up the socket area so you can see it more and kinda show off the mobo more. Temps wise, I thought there wouldnt be much point in a single 120mm rad in one of these closed loops. I thought there might be one REALLY good one out there. Anyways, I wanted to change to an H100 or something of the like, but I'll have to get a new case first, which is a bit of a bummer.
Thanks everyone for your help! :)
Against a high end Air cooler (just like Noctua D14) a single 120mm closed loop water cooling would be a little worse...
Cooler Master Seidon is just great, I love what they are doind with their closed loop water coolers, but I don't know if it would beat a Noctua D14, A 2x120mm or a single 140mm (like the corsair H90) could be better, but they are much larger.
I personally would go for a XIGMATEK Dark Knight II.  It's half the price of the H100 ($50 vs $100), is smaller than the gaint that is the NH-D14, and in Logan's test, actually outperformed the H100!
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029&Tpk=xigmatek%20dark%20knight&IsVirtualParent=1
good options. That xigmatek looks nice, here is a really good reviewer noctua wise. I think it's the best choice. If you don't want to watch so much, just skip to the conclusion at: 13:50.
http://www.youtube.com/watch?v=07XTN0Qll2o&list=LLw1g4i4Y6Bggh5-Kb0KWB9Q
