Best Budget Build for Gaming and editing
Hello all!
Been looking around for a bit about building a PC for light editing and also having the ability to run most games on high settings! Looking to spend between $500 and $600, already have an ssd that i will add to the pc after i build it but would also install atleast 1tb driver for storage. I'm really inbetween intel and amd and not sure what would be better for my needs, already have my keyboard and such so just looking for the pc. Also live in the US so getting the parts shouldn't be a problem. Lastly whatever way i go, i'd like to have the ability to upgrade it easily as i move into move video editing through school. Oh i need to have a wireless card in there too, so whatever is most reliable for that will work.
Thanks!
Was just looking at a similar question here, might prove useful....
https://teksyndicate.com/forum/build-pc/editing-build-%C2%A3500/182403
http://pcpartpicker.com/p/xWtyt6  that should not be too bad
I don´t know a lot about wireless cards but the other components I´m sure could help you
http://pcpartpicker.com/user/Obstinated/saved/n8BhP6
This is what I would go for
http://pcpartpicker.com/p/Dkj923
heres the two i've came up with, how are they? http://pcpartpicker.com/p/jfxddC
http://pcpartpicker.com/p/zMXqP6 also was messing around with an intel core i3, or even a pentium g3258 will those be able to perform like i need them too?
