You don’t “need” it. My ubuntu router runs on a old q9650, and it hosts 4 lxc containers all running openvpn instances with aes-256-cbc encryption. CPU usage has never been an issue.
Depends. However, pfSense is going to require it in 2.5 and later:
https://forum.pfsense.org/index.php?topic=129842.15
pfSense is far from your only option. I’d be surprised if there weren’t more people who’d just installed Ubuntu server on a random 2 nic machine and enabled forwarding than there are users of pfSense
The main advantage to using a vanilla server distribution over a gui firewall distribution is everything you already know about securing servers with iptables is directly applicable to your router setup. It’s really just another server.
I’ve been running a j1900d2y asrockrack mini-ITX with a picopsu for a couple years now.
I setup CentOS using iptables for routing / firewall duties.
That looks really cool! How’s the power efficiency on that? I’m thinking about getting the i3 version and a separate wireless access point.
Maybe something like this?
https://www.newegg.com/Product/Product.aspx?Item=0XM-0013-00050&cm_re=wireless_access_point--0XM-0013-00050--Product
I use a pc engines apu2c4 running OpenBSD myself as my router on a 500Mbit fiber line. They’re really small (tiny) form factor 4 core AMD jaguar embedded PCs, so they can run pfsense, linux, FreeBSD, NetBSD, etc, too.
The only caveat is, no graphical output, so you have to use a serial cable to do the installation and initial setup, but after that you can just ssh to them, of course.
Just plugged it into my cheap ass power meter and seems to be drawing 10-14W or so. It isn’t under high load.
It is also warm to the touch.
Oh nice that’s pretty good!
And over the last 4 hours, a min/max of 1.2 - 21.3W.
So I guess it is pretty efficient!
That sounds about as good as it gets!
i have california internet 350 down 10 up my upload is so pathetic
Putting this one back to sleep. Please start a new thread if you’d like to continue the discussion. You can always link the new topic to this one.
