Best bang for the $$$
    So I'm saving up cash now for a DDR4 system when they come out.  I am thinking about Water cooling my GPU and maybe my CPU.  I don't overclock, i want something near silent, and something that will allow for simple water add on in the future.
What i want is
www.youtube.com/watch?v=rg_DzdHGgN4
What i think i'll end up getting is the
www.youtube.com/watch?v=cQOPK-OgvnM
Or the
www.youtube.com/watch?v=miJGkTNT7_U
I Also like the NZXT Source 530 but it just look small.
www.youtube.com/watch?v=Q-9Rmn624bc
So is the extra $100 for the Primo Really worth it or do you guys think the Luxe or Arc XL will do just fine?
I'll be cooling the video card with the Corsair HG10 Block and a Corsair Hydro 105 or 110.
Dude, Enthoo Pro... Primo is to expensive, and Luxe offers only lighting. Take the Pro. It is far from silent, but you can make it really quiet. Instead of push or pull configuration, use push/pull with the fans at lower speed. Also use more fans at low speed instead of less fans at high speed. As for the light effects on the case - Cooler Master Sickle flow and Bitfenix led fans are quite silent. Check Tasty PC YouTube channel for review of them. Use these at lower speed and you will have light and silence without overheating your system.
Purchase 2 14x14 sheets of aluminum, 4 tubes of pcp pipe or angle iron for $20. Make a test bed.
Ethoo Pro.. Its the 2014 Case of the year...
I like the Phanteks Enthoo Pro myself i just want the extra few inches on top. I want to do a Push and Pull on the Radiator.  I like that with the Luxe I can throw pull set on top of the case and hook the radiator straight to the Frame.  I like using the Cooler Master 4 Pack of silent fans.  they have very limited Air Pressure so im thinking of just using them as the pull system and getting some Cooler Master Blade Master for the push since they seem to have the highest Air Pressure and is are PWM fan.
I like test beds but with kids around i cant leave parts out.
