I was going to get the nzxt Phantom 410 (in red) but it is no longer on sale so any suggestions?
What are your requirements?
Does look factor in? what are your preferences?
Front panel IO factor?
Do you want 500 fans?
Do you need to store 50 hard drives?
Do you want top or bottom mount PSU?
Are you looking for a monolith or something more along with the typical case?
I like the NZXT Source 210. It's simple and has plenty of room, while staying relatively small.
There are ofc a lot of cases to choose from.
NZXT Phantom 240 maybe?
Not sure if you could get it in red.
there will be an ssd and a hard drive. I need a bottom mount psu with a basement and I would prefer to have an atx mid/full tower. Does not need to have fans. I have a lot I can use
cant get it in red
Ah you want a red one, i exaly have a red case aswell, but its a bit more expensive.
I have the Phantom 530 red, its a awesome case.
