I have a gaming build set up but im not happy with the motherbourd but i dont know what to look for in a motherbourd. Please help.
Asus M5A97 (non LE model) or ASRock 970 Extreme4
biostar TA990FXE
The mother board I am soon to order is the Asus M5A99X Evo R2.0
After a rebate it comes out to ~$110 - 120
Biostar TA990FXE
best overclocking 990FX motherboard period
only issue is that the multi GPU performance is mediocre with it
honestly save up 25bucks and get the asrock 990fx extreme4, having used a couple of these for builds for friends, they are better then the sabertooth 990fx for clocking and the onboard cooling is better(install that fan on the fet/vrm cooler!!!)
having used alot of boards, in your price range, its REALLY worth spending a few bucks more to get the 990fx extreme4, you will be alot happier with it then with the 970 version :)
