Title says it all give or take a few dollars...
Gigabyte ga-990fxa-ud3 isn't too bad. Also Asus m5a990fx pro is good as well.
shrimp knows it!
i use the m5a99fx pro, but i've heard good things about the UD3
What you looking to do with your computer? If you're talking about US dollars I found these:
http://www.amazon.com/Gigabyte-Chipset-2000MHz-Motherboards-GA-970A-D3P/dp/B00DJ3DWFK/ref=sr_1_3?s=electronics&ie=UTF8&qid=1388356863&sr=1-3&keywords=AMD
http://www.amazon.com/ASUS-M5A97-R2-0-SATA-Motherboard/dp/B008V9959O/ref=sr_1_5?s=electronics&ie=UTF8&qid=1388356863&sr=1-5&keywords=AMD
While I havn't used either I'd probably go with one of those if I only had $100 to spend.
Or something like this if you can afford an extra $20 http://www.amazon.com/GIGABYTE-GA-970A-UD3-AM3-SATA-Motherboard/dp/B0055Q88EO/ref=sr_1_35?s=pc&ie=UTF8&qid=1388357073&sr=1-35&keywords=AMD
Just get something from a major manufacturer like Asus or Gigabyte, I've used boards from both of them and never had any problems. I personally would tend to avoid some of the smaller manufacturs like Biostar and Asrock in these lower price range.
+1 on the Asus 990fx Pro if you can afford the extra $$$. I've heard many good things about that, probably the best budget 990fx board.
I use the Asus M5A97 R2.0, it runs cool and stable, but as they are relling you here, if you can get a 990fx chipset, lo better
Yeah
OR
I'm running an FX-6300 and a 7850. Planning on overclocking a bit...
Same with the 990fx boards, Asus, Gigabyte, or Asrock?
Thanks all
you can actually run a fx 9370/9590 on those mobos if you want to know, but you wouldnt be able to run at full speed. the tdp is 220w but it doesn't use that much power if you dont oc.
Asus M5A99FX pro R2.0 all the way. im totaly not a fan of gigabyte am3+ boards at all. they just have to much issues, i said this many many times before.
