So with fury x benchmarks out there, I have decided to finaly get 980ti. But I dont know which variation to get.
I know that all RDs are basicaly the same, but a lot of brands have already launched their own variatons of the card and more are coming. I know that it is too soon to truly know which card will end up the best, but do you have any sugestions?
I know GB had good 980s, should I go with them? Maybe I should just stick to RD?
I like the EVGA hybrid even though it's on a reference board, the boost clocks are really nice since the core is kept nice and cool. If you're interested in air, the Gigabyte G1 gaming would be my choice.
The best - the one you like the look of and + get for the best price. If money isnt an concern than the GB G1's are pretty mean. Comes down to the silicon lottery as to how good of a chip you got anyways. Be aware though that the reference cooler is close to being at its limit with the 980ti's so be sure to have adequate case flow.
Whichever you like the look of really. They are within the margin of error from each other in the tests I have seen so far with no clear leader of the pack. A clever hybrid solution is on offer but mature cooler systems is out on other cards so. I'd pick by looks tbh.
