Best 900$ build?
ok so im gonna be getting a new pc and i can spend 900$ all i need is the pc parts and case nothing else.
i hav the case i want and theres a good deal on a hardrive. i also dont want a ssd.
case : http://www.newegg.com/Product/Product.aspx?Item=N82E16811146079
hard drive : http://www.newegg.com/Product/Product.aspx?Item=N82E16822136828
"all I need is the pc parts and case nothing else."
"i hav the case i want"
Uhhh uhh uhhh,well here's this, if you really want to spend $900 though bump it up to a 8350 and 7950.
