So im gonna be getting a pc for 800$
and i want the nzxt phantom as my case (full tower)
http://pcpartpicker.com/p/2JpC
thats the case
I dont need OS , Mouse , keyboard , monitor.
Max Price is 800 - 830$
Im in the U.S if that helps
thats the case
http://pcpartpicker.com/p/Elmr
Worth the extra $2.80 imo :P
http://pcpartpicker.com/p/EluB
Basically the same thing, i thought the 7870XT would give me room for a cooler but i guess the 8350 was a little too expensive.
http://pcpartpicker.com/p/L0LN
1 8gb mem module is a fail :) for the rest looks good
No it isnt :) no performance gain with dual channel, this way he has more slots for future upgrade
i found this
http://pcpartpicker.com/p/L12b
if you not plan any extreme overclocking then the asrock is a nice motherboard
single channel will increase performance to dual channel
never heared about bandwidth (speeds)? or how you writing it in english..
I already explained in some previous thread there is no gain in dual channel while gaming (maybe only in winzip/7zip compression decompression). I have made comparisons with my results and there is NO GAIN in real life in dual channel set up nor in the higher ram frequency (again, exceptions are winzip/7zip compression decompression 10-15% ),
Here is just on of the proofs you can find http://www.youtube.com/watch?v=rgLCEMW-kfY
Please stop spamming every thread with your nonsense and go learn a bit about computers.
Your build is total crap compared to mine, btw.
Bye
