I am looking to upgrade my graphics card. I want an Amd card so I can use Open CL with Adobe premiere. I am wanting a 7970 as an upgrade. My question is what is the best 7970 in terms of cooling and noise? Thanks alot!
MSI Lighntning 7970.
i would take the Radeon HD 7970 royalAce van Club 3D
Lightning is great if you can find one, that or the MSI Twin frozr, which is fantastic for overclocking.
Lightning on newegg
I'm gonna recommend this one...
http://www.amazon.com/dp/B007LFV7RM/?tag=pcpapi-20
It's cheaper than most, and it's a solid overclocker. Also, don't forget about AMDs Never Settle Forever bundle. You can save it for later (and possibly for better bundles), or you can redeem it for the current games that are in the bundle.
