Jacco
August 18, 2013, 7:21pm
1
Hey guys!
Today I decided to make a 750 dollar AMD Rig.
This is what I made:
http://pcpartpicker.com/p/1tq5e
_________________________________________
Do you think this will be a very good gaming rig or do you think there must be changed something and still be around the same budget?
Leave a comment behind!
Greets,
J
Hands down,have fun with your bulid
This is a really good build. Stick with it.
http://pcpartpicker.com/p/1tqYB
Way better motherboard
Modular PSU
Everything else is the same except the RAM. same speed and capacity.
yeah, this build is pretty epic! im building something similar but with a very strict $680 ish budget build :/ I managed to slip in a HIS Iceq 7950 3gb for $250, and an intelcore i3-3220 for $120 in a combo with my PSU
I agree with Manimal for the motherboard. Go with a 990 fx motherboard for overclocking. The 970 isn't really up to snuff in that department.
go for some team ram for $52 on newegg (same cas latency, timing, mhz as corsair vengeance) and get a 990fx mobo
Jacco
August 19, 2013, 9:47am
8
Thanks for the replies and tips! I think I'll get the m5a99fx mobo!
