Best $60 - $70 CPU Cooler
Hey guys comment down below what you think is the best $60 - $70 CPU Cooler it can be air or liquid i didn't know where this post belonged hahah. I am looking for a silent But good looking cooler, i have a  fractal design r4 black with window.
I am a HUGE NZXT fan.  So this is what I would suggest: http://www.nzxt.com/product/detail/37-havik-120
It will fit very nicely in that case and looks awesome too.
But if you can spring for it (I know out of your price range) : http://www.nzxt.com/product/detail/82-kraken-x40-cpu-cooler
The noctua nh-d14 its ultra silent double fan and also gives the best air cooling for any cpu, i used the new fx9570 with this cooler and never heats up always in 33 celsius on idle and with overlock 45 celsius, the price its 76 dollars on amazon, its a  little over the price but its the best of the best ,even better than watercooling.
here is the link:http://www.amazon.com/Noctua-Heatpipe-Bearing-Cooler-NH-D14/dp/B002VKVZ1A
+1 on the Noctua lineup. I have the NH-U12, running an 8350 and at idle, it usually sits around 37°C, and never goes above 45°C when doing extended gaming. Dead silent too, even when gaming. Kid you not, I seriously can not hear it, and the loudest thing now is my Fractal Design case fans, making me want to go and get some Noctua case fans to replace them. Can not recommend them enough!
The other option would be liquid cooling, but considering I don't do any serious overclocking, I would rather have my system be quiet.
Be careful of using AMD temperature readings from the CPU, they are known to under read dramatically until you get to an actual temperature of ~55°C, where they seem to be good enough but still get more accurate as the temperatures increase. This probably was allowed to occur because AMD figures the actual temperature doesn't matter if your this cool anyway, but its worth noting when it comes to heat sink comparisons or reviews.
Personally I really like having a 140mm AIO (Corsair H90 $75 free ship via newegg if your in the states) as the rear exhaust in the my Black Define r4 (non-window, top and side blocks in) as it cools the CPU plenty well enough without heating the case temperatures up in the slightest. I have also found as the fan is on the inside of the radiator (running in push) on a well sound deadened case its fairly quiet and fan speeds don't get very high even fully loaded on my I7 4770K.
A large Noctua cooler like the D14 is also a possibility that's also just above your price range, it will get great temperatures with very low noise. However its huge (can cause clearance issues with ram ect), heavy (lots of force on mobo), vents CPU heat back into your case and if looks matter to you that's also likely a problem because not only does it have classic (horrid) Noctua fan colors, its also lop sided due to its use of a 140mm center fan and one 120mm on one side but not the other... which cools well but looks very strange to say the least.
Personally I'd recommend AIO water cooling, especially now you can use NZXT's G10 bracket to convert any older units you have into GPU water blocks with great results, which helps justify at least some of the extra cost. For under your $70 budget (in the states) you can normally get the Thermaltake Water 2.0 Performer (120mm rad 2xfan), however currently Newegg is doing a (crazy) 23% sale AND $25 mail in rebate on the Thermaltake Water 2.0 Extreme (240mm rad 2xfans). This brings the price down to $60 (free shipping) from around $100, making it incredible value if your willing to jump through the hoops required to get the mail in rebate, but even at $85 its still a good deal. This unit will cool fantastically and even matches the black with white blade color of the existing silent series fans in the case, however I'd recommend taking the top block off and mounting as an exhaust over mounting in the front (will fit fine in either) as it will result in much lower temperatures for your HDD's.
There are also air cooling options that are nice on your budget like the NZXT HAVIK 140 (2x 140mm fans) @ $50 or Noctua NH-U12P SE2 (2x 120mm fans, very quiet) @ $60 and even the Cooler Master Hyper212Evo (1x120mm upgradable to 2x) $30 if you upgrade it to a pair of decent fans.
Yes AMD CPUs get hotter, because they have a higher TDP than Intels...  Which mean they are capable of getting hotter...
