Best 40"- 50" TV
Hi guys,
I’m looking for a Smart TV to watch movies and play some console games. My budget is 370$ (280.000 pesos).Brands i consider are LG, Samsung and TLC. There are 2 types of panels, IPS which has weaker contrast and VA which has better visuals. LG TVs suppossedly last longer and have better OS than Samsung, but the interface is bad in both. AFAIK Android TV is the best OS, I could also get Chromecast TV later on.
So which TV should I go for?
Samsung
https://www.solotodo.cl/products/51339-samsung-un43nu7090 43” IPS Panel
https://www.solotodo.cl/products/85572-samsung-un43tu7090gxzs 43” IPS Panel
https://www.solotodo.cl/products/85571-samsung-un50tu7090gxzs 50” (>300k) VA Panel
LG
https://www.solotodo.cl/products/64112-lg-43um7100psa 43” IPS Panel (white pixel issue)
https://www.solotodo.cl/products/80497-lg-43un7300psc 43” IPS Panel
https://www.solotodo.cl/products/82028-lg-49un7100psa 49” IPS Panel
https://www.solotodo.cl/products/79296-lg-50un7300psc 50” (>300k) VA Panel
TCL ( Android TV)
https://www.solotodo.cl/products/85719-tcl-40s65a 40" TN Panel
https://www.solotodo.cl/products/85390-tcl-40s65 40 " TN Panel
https://www.solotodo.cl/products/56132-tcl-40s6500 40 " VA Panel
https://www.solotodo.cl/products/86638-tcl-50p615 50 " VA Panel
I appreciate your help
If at all possible, I would wait a few more months for new models or this year’s good models to go on sale. Plus you’d be able to save up a little bit more. TVs are one of those things that I’d prefer to save up and buy something nice considering the amount of time you use it
That being said, if I was desperate and needed a budget tv I’d look into TCL and Hisense
If you’re looking for “best” in your price range, check rtings.com. They have a shitton of TV reviews in all price ranges, maybe you’ll get lucky there.
Can’t really help you with specific models though since this wasn’t a price range I looked at when last I bought one.
How to visually qualify a TV
  1. Go to the TV Store
  2. Set all the TVs to Golf
  3. Then one by one - look at the grass.
No animated movies. no roughness factor.
Sadly i cant wait to purchase this TV. After much research ive come to this top TVs so far:
TLC:
tcl-55p615
tcl-50p715
LG:
lg-50un8000psb
What do you think?
Thanks guys
