Best 2.0 Channel Desktop Speakers?
I have heard a lot about the Audio Engine A5's and A2+ but they are just a bit to expensive for my taste.
The A2+'s are more in my range but I would NEVER buy them because of that rear mounted volume nob (I mean what the fuck was the design team thinking!).
Any ideas for something of similar quality for a better price ??
Microlab Solo 6c's ???? Depends if you can get them where you are. Should be cheaper than A2+'s. Best to always hear for yourself before buying speakers if you can.
I use Creative T40s. they're cheap, not overly big and the quality is descent. I would make rather have some A5s but yeah bit to pricey for me.
http://au.creative.com/p/speakers/gigaworks-t40-series-ii
Kanto YUMI/YU3/YU5?
Volume knob is on the front.
I have been using the Bose Companion 5 multimedia speaker system for around 6 years now. Great speakers especially for gaming and watching movies. But the cost is around $399 atm so yea.
So i recently bought a pair of Klipsch RB 81 II and those are really awesome. They sound really great, if you like a horn tweeter, and their bass is really punchy on these beasts.
Would definitely suggest these:
http://www.amazon.com/Apple-MD827LL-A-EarPods-Remote/dp/B0097BEG1C/ref=sr_1_1?ie=UTF8&qid=1417319397&sr=8-1&keywords=Apple+earpods
This is a little late, but The Wirecutter recommends the M-Audio AV40, http://thewirecutter.com/reviews/best-computer-speakers.  I've been thinking of downgrading from my Z5500 setup as I could definitely use something smaller, but haven't been able to find the AV40s as of a month ago.  Maybe they've been discontinued?
Myself has boughted a new TV with 'bee in a tin can' audio system ,I want these now instead of KRK RP5 Rokit 5 G3's (was planning to get one at a time)?
My first post, but a topic im good at. Check out these speakers
http://www.parts-express.com/dayton-audio-b652-air-6-1-2-bookshelf-speaker-pair-with-amt-tweeter--300-651
with this amp
http://www.parts-express.com/dayton-audio-dta-1-class-t-ac-dc-battery-powered-mini-amplifier-15-wpc--300-380
i use the non AMT version of that speaker and the same amp and they sound really good.
