Best $150-200 Monitor?
Hey guys, I have $200 bucks and want to upgrade my monitor for Titanfall (Yes I now it comes out in March). I currently play on a 1280x1024 monitor by Dell. I would like something with a good response time and and nice bezel (Not to thick and not to slim). Do you think I should wait till I can get $250-300 and buy one then ? As of now these are my two options.
Asus VS239H-P(newegg): http://www.newegg.com/Product/Product.aspx?Item=N82E16824236288
Samsung S22C650D(newegg): http://www.newegg.com/Product/Product.aspx?Item=N82E16824001834
Which one is the best out of the two ? All help is well appreciated. Thanks :)
Before you spend money on a new monitor can your current graphics card play games at 1080p?
Yes I have an R9 270 from XFX.
Out of those two i would go with the ASUS one, or this one (http://www.newegg.com/Product/Product.aspx?Item=N82E16824236335)which seems to be a bit better for not much more(same with rebate even). Since you intend on using this for gaming you could consider one of the BenQ TN panels. There is a lot of hate floating around for TN panels but you will gain faster response times with the loss of some color accuracy. So its really whats important to you.
You would recommend a used BenQ XL2420T (minor scratch not visible when in game) for $180 or the one the monitor that you recommended ?
I have a Asus 248qe it is around $200
Actually ya that would be a good deal if you think the condition is ok. Thats actually a 120hz monitor which will be really nice if your rig can push it over 60 fps. Considering the thing retailed at around $400-$450 new i would say grab it.(keep in mind it will still be less color accurate than an IPS monitor though my buddy actually has this exact model and its not that noticeable)
Thanks guys for the all the feedback.
I'm looking for a monitor as well for my newest rig. Would those Asus monitors serve me well?
