Stampy
March 6, 2013, 1:59am
1
ok so i have 1200$ and i want a 200$ water cooling kit with the nzxt switch 810 black (169.99$)
so basically a 1000$ system with a 170$ case
ill be using sony vegas and rendering vids and playing games on 1 monitor (games : dead space 3 , gta 4 , minecraft , diablo 3 , and skyrim)
and could you guys leave a link to a water cooling kit.
Thx
I suggest you go with AMD parts, is this a problem?
If not, i will go on to build you a rig.
Here is my AMD build based on price/ performance, and also remembering what tasks you have in mind..
http://pcpartpicker.com/p/HO7b
Intel build.
http://pcpartpicker.com/p/HOb7
Watercooling:
http://www.frozencpu.com/products/16894/ex-wat-222/XSPC_Raystorm_750_RX360_Extreme_Universal_CPU_Water_Cooling_Kit_w_Free_Dead-Water.html?tl=g30c83s137
Stampy
March 6, 2013, 2:25am
6
http://pcpartpicker.com/p/HOqy how bout this??
Seems good :)
I forgot to remove the cooler in my parts list :P
Stampy
March 6, 2013, 2:32am
8
should i get a cheaper 7950 and get better fans for the raid?
You could go cheaper with the GPU, remember you have a $20 off rebate with the one i chose you, and you also get 2 free games, which all AMD GPu's should come with..
Yes, i suggest you get these fans, if you want best air pressure:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608026
Not cheap but are well worth it if you can push your budget a little more, if not, these will do well too:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181026
