Planning on getting new PC soon, and wondering which case fans I should get.
Here's the current build: http://pcpartpicker.com/p/1GRZC
It has a max budget of $550...
I'd like it to be whisper quiet, anything under 40Db.
There's a lot of space between whisper quiet and 40dB. Look into Cougar Vortexes; fantastic fans for SP, CFM, and price to performance, both in 120mm and 140mm variants.
Bitfenix's Spectre Pro PWM's are extremely good. On paper at least.
ಠ_ಠ
Some of the worst fans ever made; on paper, sure, they look great, but they are rubbish in reality, and far from "rated" specs.
Thanks for replying so early. I already had this bias in my mind that Cougar products are terrible, the cases at least.
Does this look good to you?
http://pcpartpicker.com/p/1GS96
If you don't want to OC your CPU, it's great.
