So it can go a little over budget like $250 over but looking for a micro itx or mini itx build with a nice you and if possible ddr4 memory. But that's with the Broadwell cpus if it's an option.
So yeah let me know what's the best option thank you
More info please.
matx build:
Did some edits to the 1150 build.
http://pcpartpicker.com/p/HYwW8d
Newer Xeon E3-1231 V3. 100mhz faster, and a little bit cheaper. I've used this chip - it's just like the Xeon E3-1230 V3.
Matched RAM.
X99 looks nice. Unfortunately I'm not sure what type of productivity that @Nick_Basyuk is doing so can't really choose between them at the moment.
Okay torally forgot about amd :)
Gpu : any manufacturer as long as it's the hest for the application
Cpu : intel
Storage: could be hybrid where most current work will be done on like a ssd then stored mechanical in terms of size it would be nice to have 1tb in storage at least
OS: I got one already to go not counted as part of the price of build
No not really high end gaming hust mainy a workhorse and productively desktop
Monitor: if it fits within budget then it would be great but if not then I can pick up a low end one then get a better one later :)
Keyboard: doesn't have to be special at all...
But thanks for the amazingly fast reply :)))!
You'll need a xeon or something that will have low risk of data corruption due to hardware failure from overclocking. This is more of a "business and productivity build."
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor ($241.99 @ SuperBiiz)
CPU Cooler: Cooler Master Seidon 120M 86.2 CFM Liquid CPU Cooler ($64.99 @ Newegg)
Motherboard: Asus H97I-PLUS Mini ITX LGA1150 Motherboard ($100.99 @ SuperBiiz)
Memory: PNY XLR8 16GB (2 x 8GB) DDR3-1600 Memory ($94.99 @ Amazon)
Storage: A-Data Premier Pro SP600 256GB 2.5" Solid State Drive ($84.99 @ Amazon)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ Amazon)
Video Card: Sapphire Radeon R9 290 4GB Tri-X OC Video Card ($296.98 @ Newegg)
Case: Cooler Master Elite 130 Mini ITX Tower Case ($42.70 @ Mwave)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($78.99 @ SuperBiiz)
Total: $1076.61
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2015-04-27 09:34 EDT-0400
It turns out that mITX X99 build with your budget is possible. With a quality case/PSU and a 500 GB Intel SSD. Amazing. But no graphical performance for you.
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor ($372.95 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($28.89 @ OutletPC)
Motherboard: ASRock X99E-ITX/ac Mini ITX LGA2011-3 Motherboard ($297.86 @ Newegg)
Memory: G.Skill Ripjaws 4 series 8GB (2 x 4GB) DDR4-2133 Memory ($90.98 @ Newegg)
Storage: Intel 730 Series 480GB 2.5" Solid State Drive ($243.99 @ SuperBiiz)
Video Card: EVGA GeForce GTX 750 1GB Superclocked Video Card ($98.99 @ Newegg)
Case: Fractal Design Node 304 Mini ITX Tower Case ($66.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($53.99 @ SuperBiiz)
Total: $1254.64
Generated by PCPartPicker 2015-04-27 09:10 EDT-0400
I hope it's compatible, I just threw it together.
If the system is mainaly a work Horse, and you can afford a 5820k, then i would recommend that.
It will be allot better if you do allot of rendering stuff.
The Xeon E3 is not a bad option either, but then you have 2 cores less.
So it depends allot on the typ of productivity you do basicly.
- If you do allot of rendering and stuff then the 5820k.
- If its just an office pc, with various all day use office applications, then the Xeon E3 is more then enough.
