Best $100 MoBo
I have about $100 USD to spend so I thought My PC might be due for a MoBo upgrade.
Things I Need:
AM3+ Socket
Crossfire Support
Overclocking Support
The main reason that I want to upgrade is that I'm going to start saving up for an 8350 and I want a high quality MoBo to accompany that.  In the future I might pick up another 270x so Crossfire support would be great.
Current CPU:
AMD FX 6100
Current MoBo:
GIGABYTE GA-970A-D3
Thanks!
Well you are going to want the 990FX chip set for Crossfire and a good power design if you want to do overclocking.
Really, at $100 that isn't possible. Spend a little more, around say $140, and grab the Asus M5A99FX Pro R 2.0.
