This is a DRAFT and a template for future storage reviews. I’m thinking I’d like to organize my thoughts into a sort of checklist I can run through for each SSD review. Some of it I want to totally automate
What product is being tested?
# output of nvme list
/dev/nvme1n1 10serialnum8L KBG40ZNS1T02 KIOXIA MEMORY 1 1.02 TB / 1.02 TB 512 B + 0 B AEGA0101
… tells us it’s 512 byte formatted (may have alignment issues, can be formatted 4k natively, etc)
Does this device require any kind of warm-up?
*Some Samsung drives need a partition table to perform correctly, probably because they snoop a bit on filesystem and contents. Some may need to fill and clear the drive a few times. Others may need to *
Read Only testing
Tested on Linux _____
with Kernel version ________
Test with 1-4 CPU threads (necessary depending on CPU clockspeed)
iodepth 32 may not make sense for all devices.
# Use FIO to test 220g or up to a half an hour and output the stats.
fio --readonly --name=tempstorage \
--filename=$2 \
--filesize=220g --rw=randread --bs=$3 --direct=1 --overwrite=0 \
--numjobs=$1 --iodepth=32 --time_based=1 --runtime=1800 \
--ioengine=io_uring \
--registerfiles --fixedbufs --hipri \
--gtod_reduce=1 --group_reporting
Mixed Read and Write Testing
Numbers will be worse fio command TODO
Queue Depth 1 Testing
# Use Fio again but with more params and an iodepth of just one.
# from intel recommendations for optane
[global]
name= OptaneFirstTest
ioengine=io_uring
hipri
direct=1
size=100%
randrepeat=0
time_based
ramp_time=0
norandommap
refill_buffers
log_avg_msec=1000
log_max_value=1
group_reporting
percentile_list=1.0:25.0:50.0:75.0:90.0:99.0:99.9:99.99:99.999:99.9999:99.99999:99.999999:100.0
filename=$2
[rd_rnd_qd_1_4k_1w]
bs=4k
iodepth=1
numjobs=1
rw=randread
runtime=300
write_bw_log=bw_rd_rnd_qd_1_4k_1w
write_iops_log=iops_rd_rnd_qd_1_4k_1w
write_lat_log=lat_rd_rnd_qd_1_4k_1w
About the test platform
CPU
Motherboard
Ram Configuration & Clockspeed
Measured Ram Latency
Re-Create Crystal Diskmark numbers, but in linux via automation
this assumes there is a filesystem and argument $1 is the path to which it will write (need to add test -d imho if $1 is specified … )
# From https://gist.github.com/i3v/99f8ef6c757a5b8e9046b8a47f3a9d5b
#!/bin/bash
# This script is based on https://unix.stackexchange.com/revisions/480191/9 .
# The following changes proved to be necessary to make it work on CentOS 7:
# * removed disk info (model, size) - not very useful, might not work in many cases.
# * using "bw" instead of "bw_bytes" to support fio version 3.1 (those availible through yum @base)
# * escaping exclamation mark in sed command
# * the ".fiomark.txt" is not auto-removed
LOOPS=5 #How many times to run each test
#SIZE=1024 #Size of each test, multiples of 32 recommended for Q32 tests to give the most accurate results.
SIZE=128 #Size of each test, multiples of 32 recommended for Q32 tests to give the most accurate results.
WRITEZERO=0 #Set whether to write zeroes or randoms to testfile (random is the default for both fio and crystaldiskmark); dd benchmarks typically only write zeroes which is why there can be a speed difference.
QSIZE=$(($SIZE / 32)) #Size of Q32Seq tests
SIZE+=m
QSIZE+=m
if [ -z $1 ]; then
TARGET=$HOME
echo "Defaulting to $TARGET for testing"
else
TARGET="$1"
echo "Testing in $TARGET"
fi
echo "Configuration: Size:$SIZE Loops:$LOOPS Write Only Zeroes:$WRITEZERO
Running Benchmark, please wait...
fio --loops=$LOOPS --size=$SIZE --filename="$TARGET/.fiomark.tmp" --stonewall --ioengine=libaio --direct=1 --zero_buffers=$WRITEZERO --output-format=json \
--name=Bufread --loops=1 --bs=$SIZE --iodepth=1 --numjobs=1 --rw=readwrite \
--name=Seqread --bs=$SIZE --iodepth=1 --numjobs=1 --rw=read \
--name=Seqwrite --bs=$SIZE --iodepth=1 --numjobs=1 --rw=write \
--name=512kread --bs=512k --iodepth=1 --numjobs=1 --rw=read \
--name=512kwrite --bs=512k --iodepth=1 --numjobs=1 --rw=write \
--name=SeqQ32T1read --bs=$QSIZE --iodepth=32 --numjobs=1 --rw=read \
--name=SeqQ32T1write --bs=$QSIZE --iodepth=32 --numjobs=1 --rw=write \
--name=4kread --bs=4k --iodepth=1 --numjobs=1 --rw=randread \
--name=4kwrite --bs=4k --iodepth=1 --numjobs=1 --rw=randwrite \
--name=4kQ32T1read --bs=4k --iodepth=32 --numjobs=1 --rw=randread \
--name=4kQ32T1write --bs=4k --iodepth=32 --numjobs=1 --rw=randwrite \
--name=4kQ8T8read --bs=4k --iodepth=8 --numjobs=8 --rw=randread \
--name=4kQ8T8write --bs=4k --iodepth=8 --numjobs=8 --rw=randwrite > "$TARGET/.fiomark.txt"
QUERY='def read_bw(name): [.jobs[] | select(.jobname==name+"read").read.bw] | add / 1024 | floor;
def read_iops(name): [.jobs[] | select(.jobname==name+"read").read.iops] | add | floor;
def write_bw(name): [.jobs[] | select(.jobname==name+"write").write.bw] | add / 1024 | floor;
def write_iops(name): [.jobs[] | select(.jobname==name+"write").write.iops] | add | floor;
def job_summary(name): read_bw(name), read_iops(name), write_bw(name), write_iops(name);
job_summary("Seq"), job_summary("512k"), job_summary("SeqQ32T1"),
job_summary("4k"), job_summary("4kQ32T1"), job_summary("4kQ8T8")'
read -d '\n' -ra V <<< "$(jq "$QUERY" "$TARGET/.fiomark.txt")"
echo -e "
Results:
\033[0;33m
Sequential Read: ${V[0]}MB/s IOPS=${V[1]}
Sequential Write: ${V[2]}MB/s IOPS=${V[3]}
\033[0;32m
512KB Read: ${V[4]}MB/s IOPS=${V[5]}
512KB Write: ${V[6]}MB/s IOPS=${V[7]}
\033[1;36m
Sequential Q32T1 Read: ${V[8]}MB/s IOPS=${V[9]}
Sequential Q32T1 Write: ${V[10]}MB/s IOPS=${V[11]}
\033[0;36m
4KB Read: ${V[12]}MB/s IOPS=${V[13]}
4KB Write: ${V[14]}MB/s IOPS=${V[15]}
\033[1;33m
4KB Q32T1 Read: ${V[16]}MB/s IOPS=${V[17]}
4KB Q32T1 Write: ${V[18]}MB/s IOPS=${V[19]}
\033[1;35m
4KB Q8T8 Read: ${V[20]}MB/s IOPS=${V[21]}
4KB Q8T8 Write: ${V[22]}MB/s IOPS=${V[23]}
# rm "$TARGET/.fiomark.txt"
rm "$TARGET/.fiomark.tmp"
How fast is main memory?
Note: this is not directly comparable to tools like AIDA64…
sysbench --test=memory --memory-block-size=8M --memory-total-size=400G --num-threads=32
TODO continued
- Draft Status *
