Specs:
AMD FX 6300
EVGA GTX 760 Sc 2gb
8gb 1866mhz ram
I get between 35-50 fps on low settings 1080p. What could be causing this? Yes i've updated my drivers and shit like that.
Specs:
AMD FX 6300
EVGA GTX 760 Sc 2gb
8gb 1866mhz ram
What is your resolution scale set at? Leave it at 100%. Anything higher on the 760 will make almost unplayable. I have the same vid card but the cpu and ram is different.
Hey, I went through this also, It was pretty easy to fix, and if you haven't done this already, it may come as a surprise. Just follow this, it's simple. Before my upgrades, this .Config change boosted my fps by 20+
http://battlelog.battlefield.com/bf4/forum/threadview/2955065224296181055/
Merry Christmas! :D
