Battlefield 4 Beta CPU and GPU Benchmarks
http://www.hardwarepal.com/battlefield-4-cpu-gpu-benchmarks/#_
I cant even play the game i have a FX 8350 and a GTX 770 all my drivers are updated but even on low its unplayable.
dl the 320.49 drivers i have good luck with them getting like 65-75 on low with my fx 8350 and my gtx 760
Helped a lot but its still stutterng a lot on all settings.
yea there will continually be problems until nvidia comes out with a better driver i also advise you lower mesh quality and note it puts the ram usage to about 9.6gigs with windows tasks running in the background
If the benchmarks are to be believed, 8350 users have had their hopes ruined.
eh more or less i like my 8350 at 5.0 ghz and note its being compared to haswell and none are overclocked haswell generally does have some overclocking setbacks id like to see it compared the the previous series like the 3570k and 3770k again just to see how they all look overclocked but yea its still in beta more testing will be done in the future.
Ultra setting 2x anti aliasing with an i5 3570k at 4.5 and 7970 at 1.2. Game runs flawlessly... Except the fact that it's a beta an does weird things sometimes.
You have to remember that EA has partnered with AMD and has most likely made Intel/GTX rigs run like crap and the AMD/ATis run beautifully.
That's something EA would do, right?
nvidia drivers are a bit funny atm im doing better on the 320.49 driver than the 331.40 driver meant for bf4
^^^ i dont think EA gives a shit etherway tbh + amd mantle hasent been implemented in to bf4 yet and dosent release antill december we are playing a very ruff around the edges beta at the moment (even tho i can run it buttery butter smooth on a HD7850+FX8320 at the moment 40-50fps)
On these setings..
Benchmarks of a game that is in Beta? I don't think these will reflect the final performance at all and should be ignored. Personally i'm easily getting over 60fps with a 8350 and 2x 7870 xt's so i'm extremely happy with performance.
This is at 1440p to btw.
I agree with everything you said. The 8350 is most often compared to Ivybridge.
But I wanted to be picky and say; you can still overclock Haswell to a respectable 4.7, 4.8 if you're lucky.
On alot of the other forums BF fans have been very vocal on the Game with problems
But i have a GTX550TI (ASUS) with every thing on HIGH and thats getting 38FPS i can set the textures to ultra and get 35FPS this is the same as i got on BF3 and other then new wepons and Boats there is not allot in the game. Its the Same old thing instead of jumping out of a plane and sniping its jumping out of a Helicopter on to a building no one else can get at. I'm waiting for Titanfall
I have Sli 780 and an OCed 4770k = Impossible to play.
