Does something like this exist ?
Basically I want something I can hide away, away from my outlets and run my led light strips from. Something that could be charged would be ideal but even if it took actual batteries that would be fine.
Does this product exist ? Can someone link me ?
Thank You.
Well i have never seen a Battery powered USB Hub, but i have seen Battery Led packs, they output 5v/12V
-Fallen
Just power? a USB powerbank + any cheap USB hub without external power for distribution ^^
Cheers @Fallenzoul I don’t think I’ll go with that because I already have the strips, but it’s a good option.
@Th3Z0ne I think that might work nice. I’m not familiar with power banks in general, is there certain specs I’d need, to ensure it outputs at a low steady rate ? I don’t even know if that question makes sense, I was under the impression some where made to charge things fast, but this would only be for 3x50cm led strips.
thanks
That amperage is the maximum they can output. So a 4Amp output can deliver 4Amp max which will charge faster if the device that is beeing charged pulls them.
Usually 2A(mp) is what most powerbanks deliver on an output port.
How much A(mps) you need depends on what your leds need in a whole as these 2A or 4A are what they all together (+what ever the cheal HUB sucks) will get.
The more the Ah (amphour) or mAh (milliamphour) the batterybank has the longer it will last.
Cheers mate, pretty much answers all my questions.
