Basics about SSD's
I've heard that SSD's are limited by the amount of times that you can write something on them. (Is that true?)
Next thing is: After the life of an SSD's over, you can still read the things that have been writen on it but you can't re-write anything on it.
So if that is true, is placing windows on an SSD a good idea? Would you still be able to use that OS after you pass the write limit on your SSD? Or is it maybe better to remove your windows and place all your discographies on that SSD once it gets near the end of its life ?
yes there is a limited amount of writes but an ssd is going to last longer then a mechanical hard drive most of the time and to wear an ssd out it takes writing a large amount of data to it every day for a long time to wear out the write cycle limit of the memory.  Not sure what happens at the end of an ssds life because most people dont get there because they have a low failure rate and last a long time if your data is important it should be backed up anyways
How long does your SSD last so far?
So, if I have an SSD only, would it last a year? I'm not constantly downloading something or whatever takes up a lot of space
Theyre supposed to last about 30 years with average usage
As with most other computer hardware, if used properly, it will last longer than you will want to use it. For example, you might buy a high-end GPU right now, but it 5-6 years it will suck ass.
