Basic Physics Equipment help
I am looking for the name of the piece of equipment that measure's the voltage/wattage leaving the wall to an appliance.
After I have my system built and everything up and running I want to see how many watts it draws from my power supply. ( or just the wall if it would be the same? )
I just need to check how much room I will have for over clocking when everything is in the system at stock speeds.
Then I can check how much I can squeeze out of my 550W 80+ gold rated Seasonic Power supply before calling it a day.
-thanks in advance
a killa wat
