Hi folks, 1st time posting here. This is a hardware question but I think we’ll get a more relevant discussion in the linux category.
I’m planning on putting together a linux workstation with ‘salvaged’ server parts - I managed to get my hands on an Asrock Rack server mobo. I plan to use this for development work but as you probably know that necessarily involves goofing around on youtube and listening to music as well. Plus this is going to be my main homeoffice PC. Thing is, being a server motherboard the Asrock doesn’t come with integrated sound chippery.
What do you recommend as a basic pcie sound card that is fully supported in Linux? I don’t need fancy gamer/music production/hifi/multichannel stuff, just a replacement for the integrated sound in consumer boards with a mic input and speaker/headphone output. And whatever the blue jack is for.
I don’t want to use anything external/usb/DACs etc. Gotta be pcie, internal and as generic as possible. It just needs to be fully supported in Linux. Ubuntu 24.04 is what I’ll be using.
Thanks in advance and my apologies for the long winded post.
P.S. I don’t know the first thing about sound output from GPU cards but my monitor doesn’t have speakers. In any case I have a RTX2000 6GB and a RTX4060 - haven’t decided which one will go in this monstrosity I’m building.
P.S. 2 I did run a search but didn’t quite find direct answers, just lots of Soundblaster and other fancy cards and dacs. I’d like something simple and I’m more than a bit OCD about paying for stuff that isn’t fully supported.
Your monitor might have a headphone out. You might want to check for that.
I use one of these mobos for my everyday Linux workstation, but PCIe real estate is precious on m-ATX so I use a separate USB audio interface personally.
That said, if I were just looking for a minimal audio card then I’d probably just look up what’s available wherever I’m buying from and them cross reference support for it on the ALSA wiki, since more likely than not whatever basic card I can get will just work: Matrix:Main - AlsaProject
e.g. the Asus page has a list of cards and whether they’re supported or not, with known issues: Matrix:Vendor-Asus - AlsaProject
Thanks for the reply. I’m checking Alsa’s database but maybe my question should’ve been more in the line of “what audio chips are currently supported in the linux kernel that you know of?”
I found a few inexpensive soundcards on Amazon and eBay that are based on Realtek 8828 or 8738. This and this seem to suggest t hat they’re supported, maybe a purchase and a test are in order.
As they said, i almost always just use the gpu audio in linux.
If you need an alternative audio device, grab the cheapest used sound blaster you can find that has the ports you want. They have better audio quality and support than the realtec based stuff.
Thanks for all the replies, folks. I was under the impression that SoundBlaster (and Xonar) cards weren’t fully supported so I’d be getting pretty much the same as the cheaper Realtek-based ones.
Exactly. What I really wanted was one of them Asrock Industrial motherboards but those are hard to come by in the exact spec that I want. Infuriatingly, the perfect board for me does exist but nobody’s willing to sell them retail. Maybe in time they’ll show up on eBay or we can organize a group buy with other madmenlike minded enthusiasts.
I like the mcio ports because it lets me get more access to my slots.
I currently have a mcio to dual u.2 cable, and a mcio to slimsas with a slimsas dual m.2 card.
I am using an epyc 9124 in a supermicro H13SSL-NT with 2 dual slot GPUs, 3 m.2, and 1 u.2.
I understand your preference for PCIe, but USB sound cards are worth considering for several reasons:
Universality: USB class-compliant devices work with nearly any device that has a USB port, no drivers required. I use them to drive larger headphones from my Android phone!
Flexibility: You can easily swap the sound card between different devices as needed.
Professional Quality: Consider Behringer USB Audio interfaces. They offer entry-level pro-grade kits with significantly better and more powerful sound than onboard solutions.
Versatility: These interfaces can drive demanding headphones and connect to professional-quality microphones (both powered and unpowered), a major step up from typical gamer mics.
Control: Many external interfaces feature accessible physical volume knobs for easy adjustment.
Best of all, you can often find these on the used market at great prices due to professionals constantly upgrading!
As an Audio Engineer myself, there is a lot to be said for using an external USB thing, and they can get quite small if that was your concern. Also I can confirm a bunch that work on Ubuntu based systems.
However, if you really want a basic PCIe audio card sound blaster or other “fancy” is going to be your go to. I would go with something used, personally, cause then you can get better quality for the same price. A good DAC built in 2014 is still better than a eh DAC built in 2024.
I would just second what everyone else has said at this point other than that.
