Budget is 600 dollars, here's some basic info on what she uses it for:
-iTunes -Paying bills -Web browsing
Essentially, her old PC is kinda crapping out and she wants a new one. Budget must include a monitor (preferably ips with speakers), a wifi adapter, and the smallest case that can fit this mobo (she's used to having an all in one PC with no tower so she wants something with a smaller footprint) :
CPU: Intel Core i5-6400T 2.2GHz Quad-Core OEM/Tray Processor ($153.82 @ Amazon) CPU Cooler: Cooler Master Hyper TX3 54.8 CFM Sleeve Bearing CPU Cooler ($18.89 @ OutletPC) Motherboard: MSI H110I PRO AC Mini ITX LGA1151 Motherboard ($85.99 @ Amazon) Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory ($29.99 @ Adorama) Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive ($154.84 @ Amazon) Case: Fractal Design Node 304 Mini ITX Tower Case ($84.99 @ Directron) Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($42.99 @ SuperBiiz) Total: $571.51 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2016-07-03 16:40 EDT-0400
I think you'd be perfectly fine with a mini itx option seeing how this is more for a web browsing mother rather than a 4k gamer. A low power CPU in this case an i5 to keep things speedy without topping the electricity. 500gb SSD for all the things a good ssd is for, 500gb should be enough for even a modest gamer. one stick of 8gb RAM for the expand ability of needing more for some reason in the future. and no GPU as it would break the budget putting anything reasonable in there lol
I am going with this one combined with the R7 360 I have sitting there for my parent's build (This one jas the Pentium G3258, but I am trying to choose between that, the A10 7870/7890K and Athlon X4 870K/880K).: http://pcpartpicker.com/list/8mRWXH
Not sure about the case but it's a real small formfactor, sort of looks like they type of small case PC you might buy at a big box store. Maybe a better more mainstream case would be better.
True I was more thinking along the lines of may as well get an apu since free pci slots on a mini itx board may be needed for a wifi adapter / pci ssd / usb 3 pcie etc and afaik apu gpu components tend to be better than integrated on board gpu's
