Bash script could be more efficient?
this works, but im sure im doing this wrong
#!/bin/bash
# VPN current status
# no vpn, home vpn, work vpn
#check home
if ifconfig | grep -q tun0; then
    home=1
else
    home=0
fi
#check work
if ifconfig | grep -q ppp0; then
    work=2
else
    work=0
fi
#add checks to var status
let status=home+work
if [ $status = 0 ]; then
    output=N
fi
if [ $status = 1 ]; then
    output=H
fi
if [ $status = 2 ]; then
    output=W
fi
if [ $status = 3 ]; then
    output=HW
fi
echo $output
exit
Why do it so complicated by adding the two?
Why not check if work && home are true?
Also you can echo directly. No need for an extra output var.
fuuuuuuuck… yup, thats simple
Also, while it works fine here, ifconfig is technically deprecated.
Any of these would work:
nmcli connection show
ip a
ip l
