I came up with a single bash command line that changes the wallpaper in Gnome to an image grabbed from a subreddit. It takes the top 20 posts on the subreddit and picks the first one that contains a direct imgur link to an image.
It uses feedstail for the rss parsing, you can get it with:
pip install feedstail
You can easily modify it to work with any DE or WM, you can also change the post sorting if you want to or make it into a bash script that you can pass arguments to.
gsettings set org.gnome.desktop.background picture-uri $(feedstail -u "http://reddit.com/r/hqwallpapers/hot.rss" -n 20 -1 -f "{summary}" | grep -o 'a href="[^<>]*">\[link\]' | grep -o 'http://i.imgur.com/[^/"]*' | head -n 1)
There is probably ways to improve it or simplify it so feel free to make any suggestions.
Edit: Woops, discovered it was a little buggy, fixed now.
