Why wont this work?
TOTAL=99
tier1count=11
tier2count=22
tier3count=67
for xx in 1 2 3 ; do
echo \"Tier $xx\",\"$teir${xx}count\",\"$[ 100 * $tier${xx}count / $TOTAL ]%\"
done
How do I get it to see/resolved the nested variables?
Why wont this work?
TOTAL=99
tier1count=11
tier2count=22
tier3count=67
done
The closest I got was this…
echo \"Tier $xx\",\"$(echo '$'tier${xx}count)\",\"$[ 100 * $tier1count / $TOTAL ]%\"
done
which gave output like:
"Tier 1","$tier1count","11%"
"Tier 2","$tier2count","11%"
"Tier 3","$tier3count","11%"
I am not totally sure what you are going for, but I think you would be better off using an array instead of trying to dynamically name variables:
clifford@ubuntu-scratch:~$ COUNTS[1]=11; COUNTS[2]=22; COUNTS[3]=67; TOTAL=99; \
for xx in 1 2 3; do \
local_count=${COUNTS[$xx]}; \
local_percent=$((100 * $local_count / $TOTAL)); \
printf "Tier %i, tier%icount = %i, Percent %i\n" $xx $xx $local_count $local_percent; \
done
Tier 1, tier1count = 11, Percent 11
Tier 2, tier2count = 22, Percent 22
Tier 3, tier3count = 67, Percent 67
Because of integer rounding and the numbers you chose, each element count is its percentage of the total.
Edit: to add line breaks
#!/bin/bash
TOTAL=99
tierCount=(11 22 67)
calc(){ awk “BEGIN { print “$*” }”; }
val=1
for i in ${tierCount[@]}
do
result=calc $i/$TOTAL
echo “$i”
echo “Tier $val”,“teir”$val"count"," $result%"
val=$((val+1))
done
You can use eval
to simplify nesting, and bc
for greater control over the number of decimal places:
#!/bin/bash
TOTAL=99
tier1count=11
tier2count=22
tier3count=67
for x in 1 2 3
do
eval txc='$'tier"$x"count
echo "Tier $x", $txc, `bc <<< "scale=3;100*$txc/$TOTAL"`'%'
done
Outputs:
Tier 1, 11, 11.111%
Tier 2, 22, 22.222%
Tier 3, 67, 67.676%
thanks, I was trying to figure out how to use eval… but I couldnt get it working the way I was trying it.
I edited my previous response to make use of a “here string”, so instead of this:
echo "Tier $x", $txc, `echo "scale=3;100*$txc/$TOTAL"|bc -l`'%'
You can just write this:
Makes it a tad easier to read, and eliminates the double-echo (which might be confusing).
Here strings (the shorter version of here docs) can come in handy for other things as well — not just eliminating echo
es.
this is soo cool, i didnt know you could break a var apart like that … and smash another var in it… and roll over it… this thing is crazy
Yes indeed. But with great power comes great responsibility… You probably wouldn’t want to eval
any dynamic variable that could ever contain arbitrary, user-supplied text in it — or you may as well kiss security goodbye.
