Bash help
Say you have a directory
/dir/dir1/dir2/dirs2/subdir/subdir1/logs
Im trying to come up with a loop that will either start at the top level and work down… eg
/dir/
/dir/dir1/
/dir/dir1/dir2/
…etc
or in reverse…
/dir/dir1/dir2/
… etc
find /path -type d -exec <do your thing>
There are other ways
edit: doesn’t necessarily loop, as once its done going through all the directories it will stop
not sure about the reverse thing, you may need to store in some variables and what not.
‘ls -r’ should list recursively e.g. iterate through libraries as they come.
maybe, and im not putting my head on the block here.
but ‘ls -R (path)| sort -R’
Won’t work.
It’ll only grab directories under the /path/path2 that I give it.
Thanks for the reply.
It’ll grab all directories under the base path you give it, example:
a@host:~$ find ~ -type d -exec echo {} \;
/home/a
/home/a/1
/home/a/1/1
/home/a/1/1/1
/home/a/1/1/2
/home/a/1/1/3
/home/a/1/2
/home/a/1/3
/home/a/2
/home/a/2/1
/home/a/2/2
/home/a/2/2/1
/home/a/2/2/2
/home/a/2/2/3
/home/a/2/3
/home/a/2/3/1
/home/a/2/3/2
/home/a/2/3/3
/home/a/2/3/3/1
/home/a/2/3/3/2
/home/a/2/3/3/3
What do you require thats different?
#!/bin/bash
cmd="ls -R (path)"
dirs=´eval $cmd´
for(( i=0 ; i<${dirs[@]} ; i++ ))
do
echo "I am larger"
done
for(( i=${dirs[@]} ;i>0 ;i-- ))
do
echo "I am lesser"
done
This should “approx” do it.
The script doesnt work but it’s base idea is read a path recursively, and store as a array.
and just print, and print recursively.
I wont give you the actual solution this is what google is for, but it’ll nudge you in the right direction.
Not trying to get directories that are under the starting path.
Trying to set facls on a specific dir and then going back up the tree … set a facl for g+x so they can cd into the dir below.
I got it figured out… post the script later… if anyone cares
Dont need subdirectories… explain more later.
Your solution post makes things far more clearer :smiley: . your OP says recurse directories, which both solutions do :stuck_out_tongue:
You litterally asked for a recursive iteration back, and forth in the OP.
down and up, what ever you wanna call it.
GL on your assignment.
Say the dir treee looks like this:
And I only want these two dirs:
/tmp/tmp/DJE4/LOGS/lows
/tmp/tmp/PIA/files/tif
I needed to set a write FACL on just those two… but for the other group/user to get into either of those dirs they need ‘x’ permission on the dirs leading into those two specific dirs.
So given i needed write on:
I needed to give execute on each of these:
/tmp
/tmp/tmp
/tmp/tmp/DJE4
/tmp/tmp/DJE4/LOGS
/tmp/tmp/PIA
/tmp/tmp/PIA/files
@Eden @Lauritzen
Sorry I was so bad in the OP trying to explain what I needed.
I really appreciate attempt to help me.
I was rushing when I made the OP trying to get some help.
I cant remember exactly… but the script ended up working looked like this:
LIST=$( echo /tmp/tmp/DJE4/LOGS/lows /tmp/tmp/PIA/files/tif )
for zz in $LIST ; do
if [ -d $zz ] ; then
 echo $zz
 setfacl -m g:devs:rwX $zz
 count=$( echo $zz | awk -F/ '{print NF}' )
  let count=count-1
   while [ "$count" -gt 1 ]
     do
     NEWDIR=$(echo $zz | cut -d/ -f1-$count )
     setfacl -m g:devs:x $NEWDIR
     let count=count-1
   done
 else
    exit 0
 fi
done
Output looks like this
