So my OS drive is quadruple booted and I was wondering what the best way is to make a backup of it. I was thinking dd commands in Linux, but I wasn’t too sure if that would work. Not only that, but I’m worried that any form of restoring a backup to my OS drive which is a solid state drive, would utterly crush it/destroy it due to the amount of data written to it (consumer SSDs being fragile and what not).
Basically, what would be the best method of tackling this?
IMO, if you have a larger spinning drive, use dd to backup the whole drive to an image file on the spinner. Keep a few image files backups in rotation so that you have some increments and so that if it dies in the middle of a backup, you aren’t screwed.
To do this properly though, I believe you’ll want to dd from a live USB or something since doing it to the drive while it’s in use is problematic (or maybe won’t work?).
dd is copying the drive in a very literal way, so it doesn’t matter what the filesystem(s)/partition(s)/flag(s) are. Restoring it will give you an exact copy and if there’s extra space on the destination device, it will be left blank.
You can also use dd to just copy a partition as well, but for a full disk copy, all you really need to worry about is capacity.
I have a spare SSD 250 GB, and a 500 GB HDD that I’ll use for testing. Last time I did something this huge with files, everything went to complete shit.
Like mentioned before, use dd and copy the entire block device, not just each partition and you should be fine. If you had issues last time, it could have been due to how how you copied and how you restored.
Also unless you are using a really old SSD from the mid 2000s, you are not going to destroy it. IT may get pretty slow during the restore and/or pretty hot if it is NVMe, but otherwise you are good. Relatively modern SSDs have close to or surpasses the write cycles of a mechanical HDD.
Regarding SSDs, they have a limited lifespan with massive write volumes. It depends on your SSD, controller, and write amplication but Samsung says its TLC SSDs can handle 1064 write cycles, meaning every NAND block is written to one time. So one full write cycle would reduce its expected lifespan by 0.09%.
I also rep Clonezilla but some people get scared of the Simplified Chinese writing on the splash screen.
Clonzeilla is is something that always goes with me in my digital mercenary tool box.
