B650I Aorus Ultra ECC RAM
So in this video (AM5 mini-server: N1 Jonsbo and... may include a bandsaw - YouTube) Wendell says that ECC RAM worked on this board but then stopped after a BIOS update. Does anyone know if it has been fixed or which BIOS version worked?
This is kind of the perfect mini ITX board for a NAS, and it seems to be the least expensive B650 mITX board. Is buying this board and rolling back the BIOS a bad idea? I am planning to build a NAS.
I wondering the same thing, hope he pops in and updates us
I’d also love an update about this. Currently trying to decide which platform to go with for an ITX NAS / Jellyfin server.
still not working, works on the PG ITX from asrock though.
Does the GPU slot support PCIe 4 x4 bifurcation? I am looking for a SFF build to demo AI accelerators that we are building. The idea is to plug in an expansion card like ASUS Hyper M.2 x16 in GPU slot and then plug in 4 accelerators, each taking up a x4 lane (even PCIe 3.0 is fine)
Bifurcation may also be relevant for NAS builds with some insane M.2 RAID 0 madness.
The slot supports x16, x8/x8, x8/x4/x4, and x4/x4/x4/x4.
Hi,
Did anyone manage to get ECC running on this motherboard?
I see that there are a couple of new BIOS updates since then.
(F9c seems to be the latest one - 16th Aug 2023)
I would be interested in buying one but I could not fine any info beside what Wendell said in the video. @wendell did you have the chance to give it another try?
Thanks!
F9 and F20 BIOS do not support ECC memory.
Does anyone have an eye on any similar boards that support ECC (other than the PG ITX since now it’s been a few months)?
ASUS ProArt B650 has ECC memory in the QVL. I don’t have any experience with the board, but it’s rare to see that stuff on a QVL.
I can confirm the X670E ProArt has ECC.
I suspect DaAwesomeP was asking about ITX boards specifically though.
Yeah I’m trying to build a small and low-ish power NAS so ITX is preferred, but I think now it will be more cost-efficient to look at mATX.
I really wanted the 3x M.2 but I guess I now need to to decide between ECC + 2x M.2 + ITX and ECC + 3x M.2 + larger. I was going to use 2x M.2 for future write cache and 1x M.2 for future 10GbE, but realistically now that I have used ZFS more I know that simply adding more memory for read cache is probably good enough for me and the “write cache” was a misunderstanding and doesn’t work the way I thought it did.
I’m maybe still looking at the ASRock B650E PG-ITX WiFi. The larger ASUS boards are cheaper (can then pay for larger case?) and have everything I want but are bigger and maybe draw more power. The ASUS ROG STRIX B650E-I GAMING WiFi is very similar to the PG-ITX but with Intel Ethernet but unfortunately costs much more.
I’m using a SAS HBA so number of SATA ports is not relevant to me beyond boot drives really.
A short comparison (at least for what is important to me):
Motherboard Size $USD ECC M.2 SATA3 Ethernet 1 Ethernet 2 WiFi/BT
Gigabyte B650I Aorus Ultra mITX $250 no (tested) 3x total (2x CPU, 1x chipset) 4 Intel 2.5GbE Realtek or Intel depending on revision
Gigabyte A620I AX mITX $130 Probably not because the Aorus Ultra doesn’t 2x total (1x chipset) 2 Realtek 2.5GbE Realtek RTL8852CE
ASRock B650E PG-ITX WiFi mITX $290 Known support, specs says “DDR5 ECC/non-ECC” 2x total (1x CPU, 1x chipset) 2 Killer 2.5GbE Killer
ASRock B650I Lightning WiFi mITX $200 Specs says “DDR5 ECC/non-ECC” so it must work considering the PG-ITX works! 2x total (1x CPU, 1x chipset) 2 “Phantom Gaming” Realtek RTL8125BG 2.5GbE Unknown
ASRock A620I Lightning WiFi mITX $140 Specs says “DDR5 ECC/non-ECC” so it must work considering the PG-ITX works! 2x total (1x CPU, 1x chipset) 2 “Phantom Gaming” Realtek RTL8125BG 2.5GbE Unknown
MSI MPG B650I EDGE WIFI mITX $260 Unknown 2x total (1x CPU, 1x chipset) 4 Realtek RTL8125BG 2.5GbE Unknown in M.2 E slot
ASUS ROG STRIX B650E-I GAMING WiFi mITX $312 ECC support in spec, support claimed: Reddit comment 2x total 2 Intel 2.5GbE Unknown
Asus ROG STRIX X670E-I GAMING WIFI mITX $425 No ECC support in spec 2x total (1x CPU, 1x chipset) 2 Intel 2.5GbE Unknown
ASUS ProArt B650-CREATOR ATX $260 ECC support in spec 3x total (2x CPU, 1x chipset) 4 Realtek 2.5GbE Realtek 1 GbE Unpopulated M.2 E slot
ASUS ROG STRIX B650E-F GAMING WIFI ATX $260 ECC support in spec 3x total (2x CPU, 1x chipset) 4 Intel I225-V 2.5GbE Unknown
ASUS PRIME B650M-A-CSM mATX $155 ECC support in spec 2x total (1x CPU, 1x chipset) 4 Realtek 2.5GbE None?
ASUS PRIME B650M-A II-CSM mATX $173 ECC support in spec 2x total (1x CPU, 1x chipset) 4 Realtek 2.5GbE None?
ASUS PRIME B650M-A AX II mATX $180 ECC support in spec 2x total (1x CPU, 1x chipset) 8 Realtek 2.5GbE Unknown
ASUS PRIME B650-PLUS ATX $192 ECC support in spec 2x total (2x CPU) 4 Realtek 2.5GbE Unpopulated M.2 E slot
Asus PRIME B650M-A AX mATX $200 ECC support in spec 2x total (1x CPU, 1x chipset) 8 Realtek 2.5GbE Unknown
ASRock B650 LiveMixer ATX $150 ECC support in spec 3x total (1x CPU, 2x chipset) 2 Realtek RTL8125BG 2.5GbE Unpopulated M.2 E slot
ASRock B650M Pro RS mATX $135 ECC support in spec 3x total (1x CPU, 2x chipset) 4 Realtek RTL8125BG 2.5GbE Unpopulated M.2 E slot
ASRock B650M PG RIPTIDE WIFI mATX $170 ECC support in spec 2x total (1x CPU, 1x chipset) 4 Realtek RTL8125BG 2.5GbE Unknown
Look on ebay for Gigabyte MB10-Datto :rofl: (it’s not going to satisfy your needs I just think they are a funny product)
Thought I’d give F30 and F32a a try on my Rev 1.0 board.
It doesn’t post with my Kingston sticks on either version.
